Highlights
Powered by NXP®/Freescale Vybrid Processor
The Colibri VF50 is a SODIMM sized computer module based on the NXP®/Freescale Vybrid embedded system-on-a-chip. The Cortex A5 CPU peaks at 400 MHz. The module delivers cost effective CPU and graphic performance with minimum power consumption.
Ideal for low-cost and feature-specific applications
Colibri VF50 is ideal for applications including simple HMI in appliances and industrial machines, secure control of infrastructure and manufacturing equipment, automotive infotainment and panel cluster, ruggedized wired and wireless connectivity, and control of mobile battery-operated systems such as robots and industrial vehicles.
Colibri VF50 is a reference platform for Qt for Device Creation. For more details, check here
Easy Performance Upgrade
Existing customers will benefit from an extremely easy migration path between the Colibri iMX6, Colibri PXAxxx or Colibri Txx module range to the Colibri VF50 – all Colibri modules are electrically pin compatible. New customers will also appreciate the ability to select the Colibri module most suitable for their application to achieve the optimum price/performance balance without the need to support different carrier board designs.
Latest Information on Colibri VF50
You can find the latest information on Colibri VF50 at the Toradex Developer Center.
Toradex Developer CenterOperating Systems
Toradex offers free support and maintenance for Windows Embedded Compact and Embedded Linux on the NXP®/Freescale Vybrid VF5xx Computer on Module - Colibri VF50. This allows system designers to focus the application only, instead of focusing also on the OS and low-level device drivers.
Windows Embedded CE 6.0, Windows Embedded Compact 7 and 2013 are supported on Colibri VF50. The development and maintenance is carried out in-house by Toradex. WEC allows you to use Microsoft .Net Compact Framework and Visual Studio.
Carrier Boards
- No special drivers required
- Atmel touch driver
Buy Now
NXP® Vybrid™ VF5XX, Arm Cortex™-A5, 400 MHz, 128MB DDR3 (16 Bit), 128MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, 0° to 70° C Temp. Range, Availability until 2028
Quantity1-99>99
Unit Price$58.45
NXP® Vybrid™ VF5XX, Arm Cortex™-A5, 400 MHz, 128MB DDR3 (16 Bit), 128MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2028
Quantity1-99>99
Unit Price$66.50
Quantity>0
Unit Price$229.00
Quantity1-99>99
Unit Price$33.60
Quantity1-99>99
Unit Price$40.30
Quantity>0
Unit Price$69.90
Fasteners for Colibri modules
Quantity>0
Unit Price$19.90
Touch: 4-Wire Resistive Touch. 40 pin FFC cable (250mm) to connect it with a Carrier Board. No special drivers required. -20° to 70° C Temp, Range. Size: 164.9 x 100.0 x 13.0 mm.
Quantity>0
Unit Price$100.00
40 pin and 10 pin FFC cable (250mm) to connect it with a Carrier Board. Atmel touch driver. -20° to 70° C Temp, Range. Size: 173 x 112 x 13 mm.
Quantity>0
Unit Price$119.90
Plug and Play (Windows Compact Embedded 6/7 compatible). BPSK, QPSK, 16 QAM, 64 QAM, DBPSK, DQPSK, and CCK modulation schemes. WEP, TKIP, and AES, WPA, WPA2 hardware encryption Schemes. Can be setup as a ad-hoc network via peer to peer communications. -10° to 60° C Temp, Range. Size: 17 x 15 x 8 mm.
Quantity1-99>99
Unit Price$28.05
